Sets the specified port‘s internal configuration state to INVALID.
| eapsDomain | Specifies the name of an EAPS domain. |
| primary | Specifies that the primary port should be unconfigured. |
| secondary | Specifies that the secondary port should be unconfigured. |
N/A.
Unconfiguring an EAPS port sets its internal configuration state to INVALID, which causes the port to appear in the Idle state with a port status of Unknown when you use the show eaps detail command to display the status information about the port.
Enter y to unconfigure the specified port.
Enter n or press [Return] to cancel this action.
If you have considerable knowledge and experience with EAPS, you might find the EAPS loop protection warning messages unnecessary. For more information, see the configure eaps config-warnings off.
The following command unconfigures this node‘s EAPS primary ring port on the domain eaps_1:
unconfigureeapseaps_1primary port
The switch displays the following warning message and prompts you to confirm this action:
WARNING: Unconfiguring the Primary port from the EAPS domain could cause a loop in the network! Are you sure you want to unconfigure the Primary EAPS Port? (y/n)Enter y to continue and unconfigure the EAPS primary ring port. Enter n to cancel this action.
The switch displays a similar warning message if you unconfigure the secondary EAPS port.This command was first available in ExtremeXOS 11.0.
The interactive messages were added in ExtremeXOS 11.4.
